Hi, I have two WD USB 750GB, Im using Windows 7 Ultimate,
I need the two WD USB at the same time !!!
First I setup the first drive, and all seems to be ok. VCD appears as a CD drive(D:) , and WD as normal external USB drive (E:). (Password protected, and VCD enable, works fine)
THEN:
When I connect the second one, the second VCD appear as 2nd CD drive (F:) , but NONE drive appear as a second normal USB Drive(None).
What am I doing wrong? I need this second drive as No password protected and VCD disable, just as normal “NOT INTELLIGENT” drive. What I have to do?
I also have the same problem. I have one WD 500 and I bought another WD passport 500 Gb. I attempted to transfer data from one to another. I am unable. Please help.
