How to Use a USB Drive to Lock Your PC
The most common way to lock your Windows workstation is to click “Start” and “Log Off” so that no one can use your PC while you’re not around. Another way to accomplish this task has surfaced–a method that is both faster and more high-tech. Several applications allow you to use your USB flash drive as a “key” of sorts. Removing the “key” will automatically lock your workstation. Reinserting it will bring your computer back to life.
Instructions
1
Open your web browser and navigate to the website of a software developer that provides software to create USB flash drive keys (see Resources). Download and install the application by following the step-by-step instructions.
2
Insert your USB flash drive when prompted and click “OK.”
3.Click “Create Key” to turn your USB flash drive into a USB key that locks your workstation upon removal. Create a password for your USB flash key and click “OK” when finished.
4
Restart your USB key software when it closes. The software will now monitor your USB flash key. If the key is removed, your workstation will lock until the key is reinserted.
http://www.usb-drive-china.com
wholesale usb flash drive
wholesale smartphonewholesale samsung phone
cheap wholesale usb flash drive
usb flash drive factory
wholesale usb flash memory
usb flash drive cheap
cellphone case
dm8000 dreambox dm8000 dm 8000 hd dreambox 8000
dreambox dm7020 dm7020 HD dreambox 7020
dreambox 7020Dreambox dm800 HD Se
http://www.dreamboxok.com/dm500si.html
Dreambox dm500S satellite receiver
http://www.dreamboxok.com/Dreambox-DM-500-S.html
http://www.dreamboxok.com/DM500-OEM.htm
http://www.dreamboxok.com/Dreambox-DM-500-C.html
http://www.dreamboxok.com/dm500c-oem.html
http://www.dreamboxok.com/dm500s-oem.html
http://www.dreamboxs.com/dm500si.htm
http://www.dreamboxok.com/dm500si-black.htm
http://www.dreamboxs.com/dreambox-dm518s.html
http://www.dreamboxok.com/Dreambox-DM-500-T.html
http://www.dreamboxok.com/az-box-hd-elite.html
http://www.dreamboxabc.com/azbox-premium-hd.htm
Skybox S12 HD Pvr satellite receiver
http://www.dreamboxabc.com/skybox-s12-hd-pvr.html
Skybox S11 HD Pvr satellite receiver
http://www.dreamboxok.com/skybox-s11-hd-pvr.html
http://www.dreamboxok.com/skybox-s10-hd-pvr.html
http://www.dreamboxok.com/skybox-s9-hd-pvr.html
http://www.dreamboxok.com/openbox-s9-hd-pvr.html
http://www.dreamboxok.com/openbox-s10-hd-pvr.html
Openbox S12 HD PVR satellite receiver
http://www.dreamboxok.com/openbox-s12-hd-pvr.html
Openbox S11 HD PVR satellite receiver
http://www.dreamboxok.com/openbox-s11-hd-pvr.html
http://www.dreamboxs.com/Vu+Solo.html
http://www.dreamboxok.com/Vu+DUO.html
http://www.dreamboxs.com/ORTON-HD-X403P.html
http://www.dreamboxok.com/Azbox-HD-Premium-Plus.htm
http://www.dreamboxok.com/Azbox-bravoo-hd.html
http://www.dreamboxs.com/azbox-ultra-hd.htm
http://www.dreamboxs.com/Azbox-EVO-XL.html
http://www.dreamboxok.com/Az-america-s810b.html
http://www.dreamboxok.com/AZ-America-S812.html
http://www.dreamboxok.com/az-america-s900-hd.html
http://www.dreamboxabc.com/wifi-bridge.html
http://www.dreamboxok.com/e-book-reader.html
http://www.dreamboxok.com/tablet-pc.html
Strong SRT 4669X satellite receiver
http://www.dreamboxok.com/strong-srt-4669x.htm
http://www.dreamboxok.com/Strong-STR-4905-Mini-HD-USB-PVR.html
http://www.dreamboxok.com/Strong-SRT-4663X-PVR.htm
http://www.dreamboxok.com/Strong-SRT-4653X.htm
http://www.dreamboxok.com/strong-srt-4620.htm
http://www.dreamboxok.com/strong-srt-4620XII.htm
http://www.dreamboxok.com/strong-srt-4620x.htm
Dreambox Remote controller to Dreambox 500S, Dreambox 500C,500T
Remote Control for Dreambox 800 HD SE
http://www.dreamboxok.com/remote-control-dreambox-dm-800-hd-se.html
Power Supply for Dreambox
Trimax Sat Meter SM 3500 Satfinder
