How do you tell the difference? The two I bought came with firmware 2.03.31 firmware. And then I upgraded to 2.03.33. I wanna try to put Rockbox on mine. Thanks.
You have a v2 model. If it were a v1, the firmware version would start with 1.
Ok. Thanks. That’s all I needed to know.
