How to shuffle and what are those EQ bars exactly?
I read the manual and know how to turn Shuffle mode on & off, but it doesn’t do anything.  How do I shuffle songs?  They play alphabetically.
Also, what exactly are the 5 bars for in the EQ custom setting?
Thanks.
Huh. Shuffle mode is working now.  Not sure what I was doing wrong initially.  Will the shuffle order be different every time I turn the Clip on?
I’d still like a detailed explanation of the EQ custom setting bars.
Thanks, Milkerman.  I’m not as audio savvy or sensitive as most on the forum are. I thought maybe someone could spell out what each bar represents.
Do you know if the shuffle feature shuffles the music differently each time I turn on the Clip?
If a tree falls in the forest and no one is around, does it still make a noise?
Given that the shuffle feature plays a different song every time, how would you know if it’s the same or different after you turn it off and on again?
:stuck_out_tongue:
The shuffle function is unique, in that there’s a twist to it.
Once you select shuffle, a shuffled list is generated.  Using the << or >> buttons, you can back up to the last tracks, or skip forward, in the shuffled list.  If you wish to build a new list, toggle shuffle off, then on again.  The list will be rebuilt in a new order.
Bob  :smileyvery-happy:
It’s not really unique… it works like that on an ipod, for example.
