How to rip any DVD and convert any video to iPod, iPhone, PSP, Zune and Sansa Player
This is the instruction for converting video, DVD and Youtube online videos to most widely used devices such as Apple iPod, Apple iPhone, Sony PSP, Microsoft Zune and Mobile Phone.
Following program is easy-to-use, it’s an all-in-one DVD ripper and video converting tool that can convert almost all kinds of video formats for your devices. The converting speed is fast and the quality of output files is excellent. The program also supports merging files.
(1)   Download Any DVD Converter Professional and install it. Below is the interface of the program
DVD and the video formats below can be converted by this program.
supportable formats
(2)Click “Add Video” buttons to browse the video clips from your local machine. You can also simply drag-and-drop the video files to the program. If you insert a DVD disc to your DVD driver, the contents of the DVD will be automatically added to the program.
Convert DVD
If you want to download Youtube videos and convert them, you can click “youtube” button to add the youtube video URL. Oh you can copy a Youtube video URL and right-click on the middle panel of the program to paste the link, oh use Ctrl+V. Google video is also supported.
Download and convert youtube video
(3) Choose an output format. In the upper right of the program, you can find a profile list. Mp4 output for iPod, iPhone, PSP, Zune and mobile phone is available. Also MPEG-1, MPEG-2, WMV, AVI, FLV, mobile phone 3GP output formats are available. If you want to extract audio from video files, just choose mp3 as output format. And FLV output format means that you can share any video on Youtube website. If you need to make a DVD disc from videos, choose DVD Video NTSC/PAL Movie as output, then use a free program named DVDstyler to burn them to a DVD disc.
choose an output format
(4)Usually, default settings are good enough and it’s recommended. However, you can customize settings completely as you like. Video codec, video size, video bit rate, video frame rate, audio codec, audio bit rate, all of these can be customized. You can even input a value as you like except the device only accepts a certain video size. You can also specify any part of the video you need to convert by specifying the start time and stop time. For DVD, you can specify the chapters, audio language, subtitle and angle ask you like. If you want a silent movie, just simply set Disable Audio option to yes. Audio channel 1 and 2 are mono and stereo.
settings
(5)Before conversion, if you want to preview movie, just select the movie you want to preview and click the play button. There is a little red mark that you can use to go backward or forward. Also you can use it to trim the movie with the first and second button. Double-click on the preview window, the window will magnify and double-click again, it will be back to normal.
  (6)There are also some more options for more detailed settings. Click “options” button, or click menu “edit –> options”, you can find five tabs.
more options
General tab: Here you can set output folder or open the output folder, specify process priority. If you have a batch of movies that need to be converted, “shutdown computer when encoding finished” option is convenient.
Audio tab: Here you can set output audio volume, AAC parameters and mp3 parameters.
Video tab: Here you can set video preview driver, encode filters. And video resize option is available, you can set video to fit the width or the height, or expand to video size if there is black bar of output movie.
Online Video tab: Here you can login Youtube account.
DVD tab: If you don’t want to separate the DVD as titles, here is an option for you.
(7)If you want to convert some video clips and merge them into a file, please press the Ctrl or Shift button to choose the files you need to merge, then right-click on them and choose Merge Output. The first part of the output will be highlight, and the other files which will be merged will be displayed in gray and will be merged in order. If you want to change the orders of the files, please drag and drop the file in the list to change the order. If you want to cancel the merge operation, please choose the file and click Unmerge Output.
Merging files-1
Merging files-2
(8)Now, click “encode” button to start the converting. Source Files item shows videos added to the program. You can directly reach a certain output format by clicking the format in Converted list. And the downloaded Youtube or Google online videos are also easy to find. You can also directly click the “Output Folder” button to open the output folder where the converted files locate in.
How to Rip any DVD???
HEY!!! Thanks for the assist on the copywrite infringement : )
Han you help us now on how to hack secured SSLs and dDos secure servers?
The big bad money makers at the Record and Movie companies have confuzzled you it sounds like.
It’s only copyright infringement if you give it away to someone else. If you own a DVD and convert it to play anywhere else in your house or on your person, and only ONE VERSION AT A TIME, it’s totally LEGAL.  (ie you can’t play it in your living room while it’s playing on the sansa…)
My thanks to Thelastunicorn
i will check it out.
Hey, while the kids were playing on the computer, and some were watching cartoons, Daddy loaded Saving Private Ryan on the Sansa.
Earbuds on!  It’s essentially the same as watching it on the bedroom TV or the living room, isn’t it?  Same end user.
Bob  :stuck_out_tongue:
Yes, AutobahnSHO, I agree with you. And there’re so many software, like DVDSmith Movie Backup, can copy DVD contents to your HD, then play this folder with some player, without damaging the original disk.
Btw, the output files copied by DVDSmith Movie Backup can be loaded in above Any DVD Converter. If you only use this converter’s preview function, it will be totally free to watch a protected movie from your HD.
E.M. Free DVD Copy can free rip DVD to iPod, iPhone 3G, PSP, Zune.
Message Edited by howerson on 07-25-2008 01:11 AM
I tried the EM FREE software but got an error message and couldn’t go any further.
So I tried the anyDVD free trail and was able to get it.  I did have to make some changes to get audio and for it to work on my Fuze, but it worked great for the short video.  Going to try anthother DVD and if it works, purchase it.
Thanks for the tutorial, should have remembered I saw it here earlyer instead of trial and error…
Here is an all-in-one DVD ripping and video converter program that can rip all kinds of DVD’s and convert various videos to audio/video formats compatible with almost all popular mobile devices like iPod, iPhone, PSP, Zune, Apple TV, Mobile Phone, to name just a few. It works like a charm!
