Glad to hear that your problem was solved.
When you delete files from an SD card, the file system marks the space occupied by the deleted files as available for new data. However, the actual data isnāt immediately erased from the storage medium. Instead, the pointers to the data blocks are removed, making the space appear free.
The deleted filesā data remains physically present on the SD card until new data overwrites it. This is why data recovery tools can often retrieve deleted files as long as they havenāt been overwritten.
Before rushing to download and use any data recovery tool you come across, itās important to stop using the SD card immediately. Continuing to use the storge device can result in data being overwritten, which is often irreversible and can significantly reduce the chances of a successful recovery.
To recover lost files from SD card, plz check this article. This post explains three possible recovery methods in detail.
Yes, RescuePRO is a powerful and user-friendly data recovery software developed by SanDisk. When you purchase a SanDisk SD card, youāll find a free license inside the packaging, though most people discard it without even looking.
However, if you remove the SD card and insert it into a card reader, many tools can assist you in scanning and restoring files for free. Tenorshare worked magic for me. It saved me from spending over 759USD to restore my SD card! Truly a life saver.
Well I guess using data recovery software would be your go-to solution if you are computer rookie like me haha. I found this post in the search result and I guess it may help for there are several other methods to help you perform SD card recovery.
