How to replace broken clip on Clip+?
Here is a 3D printed solution.
https://www.thingiverse.com/thing:2524653
I realize this post is OLD, but my clip just broke this week. GRRR…
I came across my son’s tie clip  for work and realized it would work perfect. I clipped off the hard plastic off the back of my sandisk , took a rat tail from my husbands toolbox and sanded it down flat on the back.
Used some superglue to glue the tie clip to the san disk. Works great!!!
I’m not handy, and this doesn’t look great, but it’s quick and easy.
The binder clip even allows you to prop the Sandisk Clip Sport up.
Yeah, I ran into this problem, too. I took a clip from name badge. Glued it behind the player. Better then original!
