How to repair my book after a b-tree node problem
how to repair my book after a b-tree node problem...
i try to use diskwarrior and data rescue and seem to not working...
it is a mechanical problem or something like that...
thanks to help me...
Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
i try a different software after the problem happen and nothing can help me…
i just find a littre solution for the moment but very long… Data rescue Deep scan…
i give you news if i can get my files or not but the wd disk seem the worst way to converve photo, music or files…
do back up…
