How to Remove video and audio DRM Protection such as iTunes M4P, M4V, M4A
Question:
"Is there a program that can remove the iTunes DRM protection from my purchased M4V files?
Answer:
Many online music stores employ DRM to restrict usage of music purchased and downloaded online such as the iTunes Store, Napster music store, Windows Media DRM, etc, so you can not share your movies and songs with others, even edit or upload, the step by step guide below to show how to remove DRM from iTunes purchased music and video files so that you can play them on non-Apple portable players like Zune, PSP, BlackBerry, Creative Zen, import them into your Windows Movie Maker project, etc.
The only tool you need is Media Converter Pro, which supports most DRM video and audio files: WMA/WMV/M4A/ M4B/M4P/M4V/ASF…
Step 1: Download and install Media Converter Pro
Step 2: Run the software and click “Add…” button to load WMA or M4A, M4B, AAC, WMV, M4P, M4V, ASF files
You can import the files in three ways:
a. Load files by clicking the “Add…” button.
b. Directly drag and drop files to the left main window.
c. Right click on the left main window, click “Add files”.
Step 3: Choose output formats
By clicking the “Convert audio to:” or “Convert video to:” box, you can select the output format for the source M4P M4V files. For example, if you want to watch the DRM iTunes M4V on your PSP, you can choose “PSP, PS3” from the profile category list and choose "PSP Video MPEG-4(*.mp4) as the output format.
Note: This DRM Removal Software also allows you to customize the video/audio parameters for the output files if you are not satisfied with the default settings or cannot find the most appropriate output format for your specific mobile player. Just click the “Settings…” button to make the settings.
Step 4: Start to convert
Start remove DRM and convert your DRM protected music and videos by click on “Start” button. Then, you can enjoy the iTunes music and video without any limitation.
