How to recover deleted/lost data from iPhone X/8/7/6/6S
Missing data is a common problem, including Apple’s Contacts, Messages, Call history, Notes, Photos, Video, Calendar, Reminder, WhatsApp messages, Messenger, Voice memos, Voicemail, Safari’s bookmark, App’s photos, App’s video, App’s documents and so on. Data loss occurs when you are careless, or in a price / downgrade system, jailbreak. So, in order to avoid data loss, you have to back up important data.
When you encounter IOS equipment data loss, if you think the average recovery method and recovery operation is too complicated, the success rate is not high, but the data is very important to you, we recommend that you use the iPhone Data Recovery Tools. IPhone Data Recovery can help you simplify the complex operation steps, you only need to according to the operational guidelines on a few steps you can easily click safe to retrieve the lost data, and you can restore the data you want to choose. It supports the recovery of data that is commonly used by IOS devices, such as the data mentioned above. And it works for all iOS devices.
IPhone Data Recovery Tools in addition to recover lost data, it also has many practical functions such as: iOS System Recovery, iOS Data Backup & Restore, iOS Kik Backup & Restore, iOS Viber Backup & Restore, iOS LINE Backup & Restore, iOS Full Data Eraser iOS Private, Data Eraser, iOS Screen Recorder.
With so many functions of iPhone Data Recovery Tools, you can easily solve the various problems encountered in iOS devices.
The following is the iPhone data recovery tools recovery guidelines, you can refer to, if necessary, you can download free and try:
