I’d like to recommend one of the best SQL Data Recovery Software for recovering databases from corrupted MDF, LDF, and SQL backup files. You can quickly recover and restore full SQL data in batch mode with this SQL server database recovery software without any data loss. This software generates a log report of the SQL recovery phase steps, that can be viewed in detail on the manager’s main screen. This function can be used to evaluate the process in the future.
It has an improved user-friendly interface that makes the entire recovery process straightforward, allowing all users, both technical and non-technical, to use it without any technical skill.
