Is there a way to read the bitrate of songs on the fuze? WMP has a column but it is blank for all of the songs.
Sure…connect it to your computer, open up My Computer, click into the Fuze directory, then into the music folder, and drag the cursor over individual songs:wink:
Did not work for me-are you using Windows Vista?
nope…I’m using XP
I don’t think that cursor hover over the file thing is part of XP. It works for me because I have DBPoweramp installed. IN Explorer you can see the bit rate somewhere in the right-click-properties panel. Most player programs on PC’s can display it too.
When I right-click in explorer the bit rate is listed as zero.
