I want to add folders of mp3 music and navigate threw folders.
I add folders from my computer to the music section
I cannot see how I caqn navigate threw folders, as I can do from my computer
At the bottom of the Music menu, there is a Folders option. Note there are more options than what will show on the small screen at one time. Use the Up or Down buttons to scroll completely through the list.
I click folders, then I get to choose :
internal memory/ external memory
I choose internal memory then MTP then music, and only then I see the folders I have in the player.
Yes. This is how it works. What are you expecting? ![]()
I was expecting it to be quicker, since it is something I always do.
Thanks.
Hi, Thanks for the info on navigating. I have found the place where the folders are supposed to show, but all the folders that I created when the device was connected to my computer don’t have names. They have a number e.g. \C60000000 followed by the name ‘New Folder’. So all the folders that I created have a different number with the same ‘New Folder’ name. How can I change this? Thanks for your help.
