How to insert a desktop image into a post?
The Subject says it all.
:wink:
Thanks–
Close/minimize all your active programs, then press PrtScn. That will copy the desktop to the Clipboard. Paste it into Paint (or whatever), then save. Upload it to an image hosting site. Then you can insert it into a post like any other image.
Thanks.  And so the the trick is, uploading to an image hosting site.  No way simply to copy and paste into a post, then (I assume not)?  Seems like a more complex way to go (although, I guess it prevents the forum having to store more capacious images).
Any recommendations as to image hosting sites?
what i use is http://photobucket.com/
Cool–thanks. Wish that simple drag and drop was enabled, though …
you can input image by clicking on the add pic. button.
משקל
מאזניים
