How to increase Office 365 mailbox size?
Office 365 is one of the most secured and easily accessible cloud platform. In Office 365, the features are limited as per your subscription plan and you need to remind yourself that you should not exceed the given limitations. But if you exceed the given limitation, then you will have to delete the emails from the inbox to make space for new emails. If you don’t want to delete your emails from the Office 365 mailbox storage or save it locally on the system drive, then you can choose the other option to increase the size of your mailbox.
For increasing the size of the mailbox, you can go with Powershell. Here, I am sharing a blog where you just need to follow a few steps. For detailed information, check: https://www.datarepairtools.com/blog/increase-office-365-mailbox-size-to-100-gb/
