How to get much FFXIV Gil to play well the FFXIV Patch 2.3?
The new content of FF14 Patch 2.3 has been released for a while, most of players can’t wait to play it with friends. As we all know, in this new patch, FFXIV development has added 3 new dungeons. Today, we are glad to introduce the FFXIV dungeon Hullbreaker Isle in patch 2.3 which requires a light part of 4 players and average item level of 70 or higher to enter.
I have been making my fortune of FF14 Gil with using alchemy since the open beta. You can upgrade the manstones if you use of Alchemy profession. Critical Hit and Attack are sold at high prices thought they are the most powerful stones. However, the other manastones coming with very low price. You can turn them randomly into attack and critical hit type of manastones using the manastone exchange quests if you buy these cheap stones. And then you can turn them into higher grade stones and earn more ff14 gil though these are coming out to be low grade. you have to exchange them through traveling to various zones after buying these cheap stones.
In my point, there are the other way and I think it is a big reward, you can try to follow the way: you can obtain get some +75 HP and other scrub ones. You will spend about 160K ff14 gil when you purchasing the low level manastone. But, the reward manastones themselves are worth about 680k. You will obtain about 540k within 1 hour to 1 hour 30minutes of repeat questing. Through Alchemy and using 31 highest grade Catalysts, 4 of +15 Crit, 6 of +5 Attack manastone crit, even though it depends on when you sell them, at the time I sold my manastones I got about 1,680,000 make FFXIV Gil. I bet you will earn a large ton of ff14 gil, you also can buy ffxiv gil from ffxivingil.com good luck to you in FFXIV.
