How to get backup of Gmail accounts?
You can try the Gmail Backup tool for all of your problems of getting backup of data. This is the most reliable solution to your problem. The Gmail Backup is the light in weight that can easy to install and never make your computer slow. Gmail Backup Tool is an advanced tool that can filter all of your data and install it in the desired location. It easily supports the windows 2003 to Latest versions of Outlook. The software can create backups of only those files selected by customers.
Visit here:- http://www.gmail.topstconverter.com/
Give me give you a different option for taking the backup of Gmail Mailbox data on your Mac PC. You should use the Gmail Backup for Mac tool for downloading the data for the Gmail account and save them into multiple database formats such as PST, MBOX, MSG, EML/EMLX/. This application is very simple to operate and handle the process wisely.
You can simply go with the Gmail Backup tool for getting your database from the PST, EML, EMLX, MSG, and MBOX. This application is light in weight that can easy to install and never make your computer slow.
Visit here:- https://www.downloadtopten.com/backup/gmail/
Hey
If you want a backup of Gmail account then I would like to tell you that try to use an expert solution for safe and secure backup. The advance features allow users to download and Backup Emails, Contacts, Calendar and G-Drive items.  Free demo version of the utility is also available. Checkout
