My SD card was formatted as internal storage for Android 6.0 and it was working fine. I mounted my SD card on my second Android phone and format it as external storage but again it said “Unsupported SD card”. So I mounted my SD card on my PC and I tried to format it using Windows 10 but it failed (“Windows was unable to complete the format”). I have tried clean all
command in Diskpart
and it took an hour to be completed but at the end nothing has changed. It has two drives: 16MB and 59GB drives. I guess the SD card is locked or encrypted by Android. When I try to delete the partition by fdisk
in Linux, it will show a successful result but unable to create a new partition due to insufficient memory in virtual disk drive. I have followed this answer to unlock the SD card but the status shows that the SD card is unlocked. I have tried GParted
as well but no luck. Is there a way to reuse my SD card as a portable storage?
GParted details when I delete the partition:
GParted 0.30.0 --enable-libparted-dmraid --enable-online-resize Libparted 3.2 Delete /dev/mmcblk0p2 (unknown, 59.46 GiB) from /dev/mmcblk0 00:00:08 ( SUCCESS ) calibrate /dev/mmcblk0p2 00:00:00 ( SUCCESS ) path: /dev/mmcblk0p2 (partition) start: 34816 end: 124735454 size: 124700639 (59.46 GiB) delete partition 00:00:08 ( SUCCESS ) libparted messages ( INFO ) Input/output error during write on /dev/mmcblk0 ======================================== Delete /dev/mmcblk0p1 (unknown, 16.00 MiB) from /dev/mmcblk0 00:00:01 ( SUCCESS ) calibrate /dev/mmcblk0p1 00:00:00 ( SUCCESS ) path: /dev/mmcblk0p1 (partition) start: 2048 end: 34815 size: 32768 (16.00 MiB) delete partition 00:00:01 ( SUCCESS ) ========================================
GParted details when I try to format:
GParted 0.30.0 --enable-libparted-dmraid --enable-online-resize Libparted 3.2 Format /dev/mmcblk0p1 as fat16 00:00:01 ( ERROR ) calibrate /dev/mmcblk0p1 00:00:00 ( SUCCESS ) path: /dev/mmcblk0p1 (partition) start: 2048 end: 34815 size: 32768 (16.00 MiB) clear old file system signatures in /dev/mmcblk0p1 00:00:00 ( SUCCESS ) write 512.00 KiB of zeros at byte offset 0 00:00:00 ( SUCCESS ) write 512.00 KiB of zeros at byte offset 16252928 00:00:00 ( SUCCESS ) write 4.00 KiB of zeros at byte offset 16711680 00:00:00 ( SUCCESS ) write 8.00 KiB of zeros at byte offset 16769024 00:00:00 ( SUCCESS ) flush operating system cache of /dev/mmcblk0 00:00:00 ( SUCCESS ) set partition type on /dev/mmcblk0p1 00:00:01 ( SUCCESS ) new partition type: fat16 create new fat16 file system 00:00:00 ( ERROR ) mkfs.fat -F16 -v -I '/dev/mmcblk0p1' ( EXECUTING ) Failed to execute child process “mkfs.fat” (Input/output error) ( ERROR ) ======================================== Format /dev/mmcblk0p2 as fat32
Results for zeroing:
sudo dd if=/dev/zero of=/dev/mmcblk0 bs=8192 dd: error writing `dev/mmcblk0`: No space left on device 7795969+0 records in 7795968+0 records out 63864569856 bytes (64 GB, 59 CAB) copied, 3824.26 s, 16.7 MB/s
Results for amd64-stdtool status:
[+] Found RCA for /dev/mmcblk0: E624. [+] Card CSD: 400E005A7B590001DED48F700R808006. [+] Write protection state: Off.
