How to formart a MyPassport for Mac
I have a MyPassport for Mac because I used to have a macbook pro. Now that I bought a pc running windows 10 I would like to know if I format my drive to be able to use it on both machines, although I don’t have access to my old mac because it doesn’t work anymore, will I lose all the information that is already installed inside my drive? Should I pass all the information back to another mac then format and then pass the information back to the already formatted drive? Because I don’t want to lose any of the information inside of it.
Hello, dixiediaz
Well, I would like to inform you that first of all backup the data that is stored on the drive using Macintosh, once it is backed up format the drive in exFAT, formatting the drive in exFAT will make the drive cross-compatible with different OS and then you can use the drive on different OS.
Formatting a hard drive will result in the loss of all data! Never format the drive before backing up your files. You can connect the hard drive to another Mac and copy all your files onto that Mac or a different storage device.
Then, proceed with reformatting:
  • Open “Disk Utility” on your Mac, select your MyPassport drive, and click “Erase.”
  • From the “Format” drop-down menu, select “ExFAT.”
Once the formatting is complete, move the files you previously backed up back onto the MyPassport drive (which is now formatted as ExFAT). Since ExFAT is compatible with both Mac and Windows systems, you will be able to read and write files freely on either platform. [Related guide - How to Format an External Hard Drive for Mac and Windows ]
Additionally, if you don’t have access to another Mac, you can download third-party software that will allow a Windows computer to read a Mac-formatted hard drive.
