How to fix portition
Hi. Yesterday I connected my new WD 4T My Book external hard drive. I did 4 partition and I noticed that I lost all software I had preinstalled on My Book. What should I do to delete this partition and get all software back to previous condition so it looks like brand new from the box. Thank you for your time.
You don’t need to delete the partitions to get the apps that comes with the drive.
You should be able to download the apps from the WD support site.
See if this helps
https://support.wdc.com/cat_products.aspx?ID=2&lang=en&i
Select your product and click on downloads.
