I have a 3TB Passport Ultra (running Windows). I set up my backup by categories, one of which is “mail.”
How do I find email items on the WD drive? I found “Contacts” (which is the the Outlook email equivalent of a personal phone directory), but I can’t find the actual emails. The backup contains 8.8GB of “mail” so there should be a lot of email in there.
Thanks in advance for information on how to access!
Hi, if you are using Outlook they should be in a .pst file locate in the same directory as the one in the computer, you should just be able to import that .pst file into outlook.
I’ll look. Thanks!
