I am unable to erase My Passport Essential using WD Smart Ware revision 2.019. Under Settings>Drive Erase, I keep getting the error ‘The drive is currently in use. Close and applications or windows currently using the drive, and then try again’.
After erasing I want to continue to use the back-up function so I do not want to format the disk using windows.
Anyone any ideas?
