How to Easily Rip and Convert BD/DVD/Video AVI, WMV, 3GP, etc
Blu-ray Disc was developed to enable recording, rewriting and playback of high-definition video, as well as storing large amounts of data. It also offer more than five times the storage capacity of traditional DVDs and can hold up to 25GB on a single-rayer disc and 50GB on a dual-layer disc. This extra capacity combined with the use of advanced video and audio codec will offer consumers an unprecedented HD experience.
If you are a DVD collector, you have lots of BD/DVD.
Or with newly released Movie, you have more than one BD/DVD. It is a funny and useful way of putting them on your computer, iPod, iPhone or any other portable players.
Here I introduce Tipard Blu-ray Converter. It can convert blu-ray disc or blu-ray m2ts files to DivX, MP4, AVI, 3GP, etc… Also this blu ray conerter converts video and rip common DVD.
How to use it:
Firstly: Download and install Tipard Blu-ray Converter.
http://www.tipard.com/guide/blu-ray-converter/dvd.jpg
Step 1: Click “Load Blu-ray” button to load your BD.
Step 2:Select the output video format you want from the “Profile” drop-down list.
Step 3:Click the “Start” button to begin your conversion.
You can have a coffee or go for a walk now! In a short while the conversion will be finished.
Tips:
Some powerful editing functions are available as followings.
1: Capture your favorite picture.
If you like the current image of the video you can use the “Snapshot” opinion. Just click the “Snapshot” button the image will be saved.
2: Merge videos into one file.
Just check the “merge into one file” option if you want to merge the some chapters or titles into one file. As default the merged file is named after the first selected file (either a title or a chapter).
3: Add text or picture watermark.
If you would like add text or picture on your video, you could do it by watermark function. Just like the picture below:
http://www.tipard.com/guide/blu-ray-converter/watermark.jpg
4: Set video effect.
Click “Effect” to adjust the video Brightness, Contrast, Saturation and Volume for you to get the perfect playing effect.
http://www.tipard.com/guide/blu-ray-converter/effect.jpg
5: Trim any clip of your video.
You can get any clip of your video by just using the “Trim” function. You can click the “Trim” button and a dialogue pops up. You can set the Start Time and End Time or just drag the slide bar to the position you want and start conversion then you can get the clip.
http://www.tipard.com/guide/blu-ray-converter/trim.jpg
6: Crop video
a. To crop your movie video, you can just drag your mouse cursor from four sides and four angles.
Crop by setting the crop values
b. There are four crop values on the lower right part of the crop window: Top, Bottom, Left and Right. You can set each value to crop your movie video, and the crop frame will move accordingly.
http://www.tipard.com/guide/blu-ray-converter/crop.jpg
Go away spammer or we will come after you with this blocker
