How to differentiate between 2 backups
Hi there.
My Book Live Duo
Can I choose where to backup to? In other words, can I create sub-folders and tell WD Smartware where to backup to? I have 2 computers connected to my NAS. May concern is that I might not be able to differentiate between the 2 backups should it be needed.
Thank you very much.
Deon
Smartware cannot backup to a sub folder, but you can create another share to backup the files. Note that Smartware will create a separate folder for each backup using the name of the computer. Check page 82 of the manual for the steps to create a new share.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705065.pdf#page=29http://community.wd.com/t5/WD-Software/How-to-differentiate-between-2-backups/td-p/577183#page=87
I wouldn’t worry about it, SmartWare is surprisingly good and keeping everything organized.
