How to convert TS video to MPEG-4, H.264/MPEG-4 AVC, MOV...
Tools Introduction:
TS Video Converter can convert TS to AVI format, convert TS to MPEG, convert TS to MPG, WMV, FLV, SWF, MOV and all the popular video and audio formats.
Input File Format Supported:
Video: MPG, MPEG, MPEG 2, VOB, DAT, MP4, M4V, TS, RM, RMVB, WMV, ASF, MKV, AVI, 3GP, 3G2, FLV, SWF, MPV, MOD, TOD, QT, MOV, DV, DIF, MJPG, MJPEG
Audio: MP3, MP2, AAC, AC3, WAV, WMA, M4A, RM, RAM, OGG, AU, AIF, AIFF, APE, FLAC, NUT
HD Video: HD TS, HD MTS, HD M2TS, HD MPG, HD MPEG, HD MP4, HD WMV, QuickTime HD MOV, HD H.264, HD RM
Output File Format Supported:
Video: MPEG-4, H.264/MPEG-4 AVC, MOV, M4V, AVI, DivX, XviD, ASF, WMV, MPEG-1, MPEG-2, 3GP, 3GPP, MKV, FLV, SWF, VOB, DV, Super VCD(NTSC, PAL, SECAM), VCD(NTSC, PAL, SECAM) , DVD(NTSC, PAL, SECAM)
Audio: AAC, AC3, AIFF, AMR, AU, FLAC, MP3, M4V, MP2, OGG, WAV, WMA
HD Video: HD H.264, HD AVI, HD MPG, HD TS, HD WMV, HD MPEG 4, HD MOV, HD ASF
Image: JPEG, GIF, BMP
Quick Guide:
Step 1: Download TS Video Converter
Download the TS Video Converter, then install and run this program.
Step 2: Load the video files you want to convert
Click the “Add File” button to browse your computer hard disc and add the video files you want to convert to the program.
Step 3: Output Settings
After you added Video files, you can select an output format for each video file and specify a directory on your computer to save the output files.
The default setting works well. Of course, if you don’t want to use the default video and audio encoding settings, just click the “Settings” button to customize these settings.
Step 4: Start the conversion
Click the Convert button to start conversion and then you can just go out for a walk or take a nap, and the conversion may have been finished when you come back: )
Tips: Edit your video
1. Adjust Effect
Click “Effect” button to open the edit window to adjust the video effects.
Brightness: Drag the Brightness adjustment bar to set the brightness of the video.
Contrast: Drag the Contrast adjustment bar to set the contrast of the video.
Saturation: Drag the Saturation adjustment bar to set the saturation of the video.
Volume: Drag the Volume adjustment bar to adjust the volume of the audio.
2. Trim video clips
Click “Trim” button to open the edit window to trim any video clips.
3. Crop video play ragion
Click “Crop” button to open the edit window to customize the video play region.
Done.
oh, bother
