Use OST to PST Converter Software for converting deleted, corrupted, lost or damaged OST files and folders in just a click. Designed with the latest scanning techniques, this software allows recovering and restoring files at a user defined location and into different formats like 15+ multiple formats Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook. The advanced recovery techniques incorporated in designing this software also gives an opportunity to preview recovered files and save them as per user defined location. Not only corrupted OST files but files with encrypted password can also be recovered using this functionally built tool.
more info-
Try this OST to PST Importer software that has ability to convert OST to PST file format with all mailbox items like: emails, contact, calendars, inbox folders, sent items, draft, deleted folder items, journals, appointments etc. this utility has a simple and easy user-friendly interface where both technical and Non technical user can easily access it without any technical knowledge. you can also try this utility free trial version.
The OST is an unsuitable file format for the Mac Operating systems but some of the users have saved their OST locally and a few of them are got corrupted. You can recover those OST files with the help of the MailVita OST to PST Converter for Mac Software. This tool converts OST files and saves them into PST file format is only supports in Outlook. There is no risk of transferring the data through this application it’s a safe and secure tool. This software support all Mac OS version.
Hii, here Ankita many users want to easy and fast steps converting OST files to pst files. The software performs fastest conversion of OST to PST, taking approx. 7 minutes to convert & extract per GB of OST data in PST format. This is innovative software complete the conversion of OST files in 4 easy steps. like- find and select then click on convert button and start your conversation and after conversation is completed. and select the folder for conversation and click save converted file.
If you want to Convert OST file to PST file format then I have a solution for you where you can easily Convert your OST file to PST file. this software provides complete OST to PST Conversion with all emails items like: emails, contacts, calendars, task, notes, inbox items and appointments. you can save your OST file to PST and many other file formats like: PST, EML, MSG, HTML, EMLX, MBOX and vCard format. This Software maintain the integrity of all data after the conversion and will not change anything in original formatting.
