How to Convert MSG to EML Format, and Save Emails on SanDisk?
If you are a Microsoft Outlook user and looking for a reliable solution to convert Outlook MSG to EML format. You can just follow these simple steps to batch convert MSG to EML file extension for Windows Live Mail, eM Client, DreamMail, Zoho Mail, and Mozilla Thunderbird.
Steps to Save MSG to EML
  1. First of all, download PCDOTS MSG to EML Converter and configure the product setup on your Windows Machine.
  2. Start MSG to EML Converter and click on the Open button to continue.
  3. Now upload Outlook MSG files to into a software interface using Choose Folders or Choose Files.
  4. Check Outlook MSG files and click on the Export button from the software menu.
  5. Choose EML from the list of saving options and after that browse a destination path (connected SanDisk).
  6. Click on the Save button to start MSG to EML migration and wait for completion.
  7. After that get resultant EML files from SanDisk SSD and use them accordingly.
Hey
Watch out the solution that I have suggest here for MSG conversion to EML files. User can easily migrate MSG files to various other formats with attachments and the bulk conversion can be performed swiftly. Free demo version of the utility is also available for users…
After successful MSG file extraction, the user needs to import MSG files to EML and to perform the same, no manual method is available. So, a user can try a granted expert third-party software. The tool has the facility of exporting many emails from MSG data and etc into EML format. without destroying the original data formatting and email attributes. Refer:- https://www.softakensoftware.com/msg-to-eml-converter.html
