How to convert .MOD video to AVI, MPG, WMV, MPEG, MPEG-4, H,264...
Question:
  1. What is .MOD video?
  2. How to convert .MOD video to AVI, MPG, WMV, MPEG, etc?
User posted image
Answer:
  1. The .MOD file format is used by various digital camcorder models (I.E JVC Everio) to save their videos. These .MOD files are often accompanied with small .MOI files (See links below) which contain the videos’ time-stamp information.
The .MOD format is simply a MPEG2 formatted video file, and if you simply wish to view the files on your computer, it is reportedly safe to rename the extension from .mod to .mpg or .avi
The known camcorder models that use the .MOD format are:
JVC: GZ-MG30, GZ-MG70, GZ-MG37, GZ-MG77, GZ-MG505, GZ-MG130, GZ-MG155, GZ-MG255, GZ-MG555
Panasonic: SDR-S100, SDR-S150, SDR-S10, SDR-H18, SDR-H200, SDR-H40, SDR-H60, SDR-SW20
Canon: FS100, FS10, FS11
  1. Now there is one professional Mod Converter that can convert .MOD video to AVI, MPG, WMV, MPEG now.
The following is a step-by-step guide on how to handle the conversion.
Step 0: Install and run Mod Converter.
User posted image
Step 1:Add files
Click “Add File” to add your video files.
Step 2: Set output video format
Click “Profile” button from the drop-down list to select the output video format such as AVI, MPG, MPEG and WMV. You can click the “Settings” button to set parameters of your output video such as Frame Rate, Bitrate to get the best video quality as you want.
Step 3: Start the conversion
Click the “Start” button to start the conversion.
Tip 1. How to join your .Mod videos
If you want to merge several Mod/Tod videos into one file you can choose them and click the “Merge into one file” to do it.
Tip 2. How to split your .Mod video
The “Trim” function also servers as a video splitter. You can set the “Start Time” and “End Time” to set the time of the clip or you can directly drag the slide bar to the accurate position. After cutting your Mod/Tod videos into small clips you can upload them to YouTube, Myspace and so on to share your video with people of the world.
User posted image
Tip 3. How to crop your .Mod video size
By using the “Crop” function you can crop the black edge of your video and you can also drag the line around the video image to adjust your video to your mobile devices. With it you can enjoy and share your DV with other people anytime and anywhere.
User posted image
Tip 4. How to save your favorite picture
If you like the current image of the video you can use the “Snapshot” option. Just click the “Snapshot” button the image will be saved and you can click the “Open” button next to “Snapshot” button to open your picture.
Here I also recommend you some High Definition video converter: HD Video Converter, Flip Converter, AVCHD Video Converter, TS Video Converter, MTS Converter, Blu Ray Ripper.
Please . . .
