How to convert .flv (flash video) to AVI/WMV/3GP/MPEG/ASF…….
As we know that YouTube, Google Video, Reuters.com, Yahoo! Video and MySpace are all the notable users of the FLV format, so we need a third party to help us to enjoy these videos on iPod, iPhone, Zune, Creative Zen and other digital devices.
4Easysoft FLV to Video Converter is dedicated to converting FLV files to mainstream video and audio formats such as FLV to WMV, FLV to AVI, FLV to MP3,
FLV to ASF,
FLV to 3GP,
FLV to MPEG, etc.
with powerful editing functions— trim, crop, merge, snapshot.
It is very easy to use. Just take a few clicks, you can finish the conversion.
Preparation: intall and run 4Easysoft FLV to Video Converter
Step 1: Import files
Click “Add File” button and add your flash video files.
Step 2: Select output video format
Select the output video format from the profile drop-down list .
Step 3: Customize output settings
Click “Settings” button in the output settings area, you are allowed to customize the output parameters such as Resolution, Video Bitrate, Frame Rate, Audio Channels, Sample Rate, etc.
Click “Browse” button, you can choose the output destination.Or the default destination is D:\My Documents\4Easysoft Studio\Output.
Or you can click “preference” buttun to choose the output destination, snapshot fold,etc.
You can also edit your files by using the funcitons of trim,merge,capture images and preview.
Step 4: Start conversion
Click “Start” button in the right of the main interface, you are allowed to start conversion. All the tasks of conversion will be finished at fast speed and high output quality.
Key features of this converter:
1. A wide range of output video/audio formats
4Easysoft FLV to Video Converter supports various output formats including MP4, MOV, M4V, VOB, XviD, AVI, FLV, 3GP, 3G2, MPG, ASF, MKV, M4A, MP3, WAV, AC3, MKA, OGG, AAC, from FLV and F4V source files
2. Compatible with various PMPs
Possessing of so powerful video converting functions, 4Easysoft FLV to Video Converter supports various PMPs such as iPod versions, iPhone, Apple TV, PSP, PS3, Xbox 360, Zune, Archos, Sandisk, iRiver, Creative Zen, MP4/MP3 Player, Smart Phone, Pocket PC, Mobile Phone, etc.
3. Trim video
Split movies by setting the exact start and end time, or just dragging the slider bar.
4. Merge video
Join separate files into one file after conversion for you to enjoy successively.
5. Crop video
Frame the video play region you want like smart scissors.
6. Capture pictures and Real-time preview
Capture your favorite pictures while previewing movies. It can be saved in default folder automatically.
7. Easier operation and better quality
8. System Requirements
OS Supported: Windows NT4/2000/2003/XP and Windows Vista
Hardware Requirements: 800MHz Intel or AMD CPU, or above; 512MB RAM or more
FLV Video Converter is also an easy-to-use FLV Video Converter which can convert mainstream video files to YouTube FLV format.
Don’t hesitate, just have a try first and hope my sharing can be helpful!
Here are some more useful softwares may help you as well:
Total Video Converter
PS3 Video Converter.
Creative Zen Video Converter
