How to convert between TS files and AVI/MOV/M4V/FLV/DivX/WMV…
Nowadays, TS files are widely used for digital television and Streaming across networks, including the internet. But sometimes, we have no idea about how to enjoy them on iPod, iPhone, Apple TV, PSP, PS3, Xbox 360, Zune, Archos, etc or share them on You tube, Myspace, etc. Now I’d like to share three useful tools which can help us enjoy TS files much easier: 4Easysoft TS Converter can be used as TS Video Converter—Convert TS file to AVI, WMV, FLV, MP4,MKV, etc; and TS Video Creator—Create TS file from all popular videos; and powerful video editor—Merge, Effect, Trim, Crop and Snapshot. 4Easysoft TS to AVI Converter and 4Easysoft TS to MP3 Converter are also powerful converters to meet our needs. The followings are the detailed guide: Part 1: How to convert between TS and other videos files with 4Easysoft TS Converter Preparation: Download and install 4Easysoft TS Converter Step 1: Run this software and add files Click “Add File” button to load the video files that you want to convert. Step 2: Set output settings You can choose the output format from the profiles drop-down lsit. You can set Encoder, Bitrate, Channels, Resolution and so on by clicking “setting” button. You can also choose the output folder by clicking “Browse”. Step 3: Start conversion. Click “Start” to begin the conversion with high output quality and converting speed. Editing Tips: Tip 1:Effect Click “Effect” button, you can set the video Brightness, Contrast, Saturation and check Deinterlacing to help you optimize the video effect. Tip 2:Trim Click “Trim” button ,you can pick up any part of your videos your videos by dragging the slider bar; clicking “Start Time” and “End Time” button or setting the values Tip 3.Crop Click “Crop” button, you can set the frame size by selectting a crop mode; adjusting the crop frame; or setting the crop values. Tip 4. Preference Click the “Preference” button you can select the output destination, the Snapshot foler, the format of the snapshot image,etc. Tip 5.Snapshot Just click the “Snapshot” button you can save any image you like when previewing the viedeo and click the “Open” button next to “Snapshot” button, you can open the image. Tip 6.Merge If you want to merge several files into one file you can choose them and click the “Merge into one file” to do it. Part 2: How to convert TS to AVI with 4Easysoft TS to AVI Converter Preparation: Download and install 4Easysoft TS to AVI Converter Step 1: Run this software and add files Click “Add File” button to load the video files that you want to convert. Step 2: Set output settings You can choose the output format from the profiles drop-down lsit. You can set Encoder, Bitrate, Channels, Resolution and so on by clicking “setting” button. You can also choose the output folder by clicking “Browse”. Step 3: Start conversion. Click “Start” to begin the conversion with high output quality and converting speed. Other editing functions, such as Effect, Crop, Trim, Merge, Snapshot are also available. Part 3: How to convert TS to MP3 with 4Easysoft TS to MP3 Converter Preparation: Download and install 4Easysoft TS to MP3 Converter Step 1: Run this software and add files Click “Add File” button to load the video files that you want to convert. Step 2: Set output settings You can choose the output format from the profiles drop-down lsit. You can set Encoder, Bitrate, Channels, Resolution and so on by clicking “setting” button. You can also choose the output folder by clicking “Browse”. Step 3: Start conversion. Click “Start” to begin the conversion with high output quality and converting speed. Try now! They will not let you down. MP4 Converter
We prefer to just say “NO” to SPAM. :angry:
