How to convert and edit between SD and HD videos
High-definition video or HD video refers to a video system of higher resolution than standard-definition (SD) video, and most commonly involves display resolutions of 1280×720 pixels (720p) or 1920×1080 pixels (1080i/1080p). As there are more and more devices and equipment available for playing and recording HD videos, it has become the favorite video format for people to enjoy more wonderful video very soon.
However, not all the software and devices can support this format, such as Windows Movie Maker; iPod, iPhone, Zune, Creative Zen; Youtube, myspace and other online video website. etc. Sometimes we still need a third party—HD Converter to overcome such inconvenience.
First of all, here is some general knowledge about what this converter can do for us:
1.Convert among HD videos, such as HD DV, HD TS, MTS, M2TS,etc
2.Convert among SD videos or general videos
3.Convert SD (Standard-Definition) video or general video to HD video
4.Convert HD video to SD (Standard-Definition) video or general video
5.Edit or polish video - Merge, Effect, Trim, Crop, Snapshot,and watermark.
Then let me show you how to use this software:
Preparationownload and install 4Easysoft HD Converter
Step 1: Add files
Click “Add File” button to load the video files that you want to convert.
Step 2: Set output settings
You can choose the output format from the profiles drop-down list.
You can set Encoder, Bitrate, Channels, Resolution and so on by clicking “setting” button.
Step 3: Start conversion.
Click “Start” to begin the conversion with high output quality and converting speed.
Editing Tips:
Tip 1:Effect
Click “Effect” button, and you can set the video Brightness, Contrast, Saturation and check Deinterlacing to help you optimize the video effect.
Tip 2:Trim
Click “Trim” button, and you can pick up any part of your videos your videos by dragging the slider bar; clicking “Start Time” and “End Time” button or setting the values
Tip 3.Crop
Click “Crop” button, and you can set the frame size by selecting a crop mode; adjusting the crop frame; or setting the crop values.
Tip 4. Preference
Click the “Preference” button and you can select the output destination, the Snapshot foler, the format of the snapshot image,etc.
Tip 5.Snapshot
Just by clicking the “Snapshot” button, you can save any image you like when previewing the video, and by clicking the “Open” button next to “Snapshot” button, you can open the image.
Tip 6.Merge
If you want to merge several files into one file, you can choose them and click the “Merge into one file” to do it.
Tip 7: Watermark
You can also add picture or text watermark with customized transparence, position and other features in your movie to personalize your videos.
Just have a try first, I’m sure you will feel satisfied!
Related tools:
In order to put some unusual video on your portable devices you need a professional Total Video Converter
It can help you with these four major functions:
  1. Convert all mainstream video and audio formats
  2. Extract audio tracks from video files to other audio formats
  3. Support all popular portable multimedia players
  4. Edit video - Merge, Effect, Trim, Crop, Watermark and Snapshot
    MTS Converter
    It is poised to convert MTS video to AVI, MPEG, MP4, WMV and all popular video formats. And you can also convert video, like TS, M2TS, TS, MOD, TOD, MOV, FLV, WMV, HD MP4, etc to any video formats you need in the fastest and most efficient way.
    DVD Converter Suite
:angry:
