How to burn DivX, XviD, WMV, ASF, RM, RMVB, MOV, AVI, AC3, MP3 to DVD, VCD, SVCD
This guide shows you how to burn DivX, XviD, WMV, ASF, RM, RMVB, MOV, AVI, AC3, MP3 to DVD, VCD, SVCD, if you want to burn other video and audio files such as YouTube FLV, MKV, TS, MOD, MTS, TOD, VOB, MP4 to DVD, VCD, SVCD, please convert the video and audio files to the formats supported by this DVD Creator software by using Video Converter.
Part1: Burn DivX, XviD, WMV, ASF, RM, RMVB, MOV, AVI, AC3, MP3 to a video VCD/SVCD disc
Part2: Burn DivX, XviD, WMV, ASF, RM, RMVB, MOV, AVI, AC3, MP3 to a video DVD disc
Tools Requirement:
AVI to VCD/DVD/SVCD Converter Pro
Download Link
Launch AVI to VCD/DVD/SVCD Converter.
  1. Select radio button “To VCD/To SVCD”
  2. Choose the “merge” or “batch” tab.
  3. Click “Open” button to open your movie file(s)
  4. (optional) Set your preference. Region “4” in red frames can set the output MPEG properties.
User posted image
  1. (optional) Set the advanced settings as following.
User posted image
  1. Click “Convert” button to start the convert task
  2. After you click “Convert” button, the following dialog will pop up automatically
User posted image
  1. After video conversion done, the “CD/DVD burning engine” will be launched automatically. Please choose the CD burner.
User posted image
  1. Please place a CD-R/RW disc into your CD/DVD burner. If it is a rewritable disc, the program will erase the disc before burning CD disc.
    Done!
  1. Select radio button “To DVD”
User posted image
  1. (Optional) Set the advanced settings as following.
User posted image
User posted image
  1. Click “Convert” button to start the conversion task
User posted image
  1. After video conversion done, the “CD/DVD Burning engine” will be launched automatically. Please choose the DVD burner.
User posted image
  1. Please place a DVD-/+R/RW disc into your DVD burner. If it is a rewritable disc, the program will erase the disc before burning DVD disc.
  2. When burning DVD is done, the DVD disc will be eject automatically. You can also find the output file at the output folder.
User posted image
Done!
