How to begin set up of WD My Passport for Mac
Is there a step by step guide for setting this up?
My iMac is running macOS Big Sur version 11.2.1
I thought this was going to be easy but not for me I guess.
Any help would be appreciated.
Thanks,
Julie
Please be informed that it is a plug and drive and does not require any software for setup. However for any other queries, you can contact our support team.
To Contact WD for Technical Support:
Are you looking to format your “new” external hard drive for usage? If so then refer to this guide on Formatting WD on Mac.
Hi, yes that is what I was looking for. I had found a step by step video for it also. Thanks for your help!
