How the heck do you make and add to playlists?
Following a recommendation in another post I was successfully able to make playlist in Win Amp but now Win Amp freezes up EVERY time I open it.
Is there an easy way to add to the playlist in Media PLayer without having to redo it all?
If not. How do I make a playlist in Windows Media PLayer?
Thanks!
Does this help, from the SanDisk KnowledgeBase?
http://kb.sandisk.com/app/answers/detail/a_id/6/kw/clip%20playlist/r_id/101834
Thanks!
Winamp & WMP sometimes get inot a tug-o-war with each other, expecailly if you try to have them both open at the same time. You may have to change your Auto-Run settings in Windows so there’s no conflict. Check the Winamp site and/or forums. There’s probably a FAQ or certainly a discussion about it.
