How long does updating take?
I bought an E250 at Radio Shack yesterday, brought it home and begane the installation process of software on my laptop. I downloaded and installed the Updater, then followed the on-screen instructions. When I checked the E250 for the firmware version it tells me I have the oldest version. So I began the update process at which point the screen on the E250 read “Writing” and the little arrows are animated. That was about 10 p.m. last night, as of right now, 7:32 a.m. it still reads “Writing” and the little arrows are animated. How long does this take? Do I need to stop the process, reset, and restart the updating procedure, or what?
______________________________________________________
ugg boots
Uggs
Message Edited by EricTom on 05-13-2010 02:39 AM
Forget the Updater and un-install it. There will be no further updates for this model so you won’t need it. Go to the Firmware Update posts ‘stickied’ (shaded posts) at the top of the board (Note that there is a different one for v1 or v2 models) and download & extract the firmware from the links contained within the post. Follow the instructions for manual installtion. It should only take a minute or two. :smiley:
