Running a WD 750GB Black drive on a Dell laptop, Windows 7.
I want to do a clean install but first would prefer to do a low level format and reset the drive to a factory fresh state.
Previously when I’ve tried this, whatever WD software I attempted to use just would not work and Iwas forced to use a third party disc wipe program, (Kill Disk). I’d prefer to stick with WD. Thank you.
I’ve read that article. Problem is, the utility that WD offers doesn’t seem to work, at least for me. I’ve tried using the Data Lifeguard but for whatever reason I haven’t been able to get the DOS version to work.
Then as per the instructions I extracted the file and copied it to a floppy. Set the BIOS to boot off the floppy I receive a message that the program I’m trying to run is incompatable with the OS, which is Windows 7.
I’m probably doing something wrong but I haven’t been able to this figure out.
