Just got the WD Elements. How do I turn it off. I push the back button, but nothing. It seems to go off when I turn the PC of or stand by. What gives? Thanks.
Hi CptSnake,
WD Elements is a plug n play external portable hard drive. You can connect it with the computer directly and start to use. You can safely eject it from computer when not in use.
Your internal HD are good. The rest ■■■■■! I already returned it to Amazon. I’ll get a Fantom!
