I see links to formatting tools and i read people saying it only hides it on THAT computer it is installed on.
I want to know if we can disable this smartware permanently so it doesn’t try and install itself when i plug it into other computers, (school, friends, library, etc).
Is there a way to completely remove it from the drive itself so that it does not attempt to install the smartware when i plug it into a different computer?
you know, the reason some of us buy portal storage devices for?
If it ain’t broke don’t fixit really applies here. If it’s working Ok for you now I’d just leave it alone I don’t use the Smartware anymore and am not going to do upgrade.
Even if you (voided the warranty and) popped the case open and took the drive out of the housing, and formatted it by connecting it directly to a SATA controller, the drive will then no longer work in the enclosure (and this is not recommended, not just because of warranty voiding). The SATA-to-USB controller in the enclosure expects that VCD partition to be there… if you remove it, the firmware on the controller will get confused when it can’t find the VCD that it’s expecting. If you leave it there, then it’s still there, no matter what you do to the other partition(s).
If you don’t want a portable drive with the Smartware VCD installed on it, then buy one of WD’s portable drives that don’t have the Smartware VCD.
I am trying to stop the WD smartware from running on my passport. My school wont allow me to run the software on their computers, PC or Mac. But I absolutely have to have the drive. How can I get around this?
You “have” to have a Passport? Or just “have” to have a USB hard drive. WD sells external USB drives without the Smartware VCD… for people that don’t want it/need it.
As of this writing, I have not finished testing the method. The drive is formatting now. Lets hope it works without the preinstalled smartware. *fingers crossed*. I will let you know if it works.
thats why I got rid of that ■■■■ drive why don’t WD just provide 2 firmware updates? one of the updates updates the smartwre for those who acualy like it and the other update removes the smartware like the U3 did.
Due to the fact that WD has no plans of removing the VCD from these drives, and that you can remove SmartWare by simply uninstalling it, I will close this thread.
