How do I partition and label My Passport
Greetings to all, I have a Windows 10 64 bit. How do I partition, label and backup to both partitions ? I would like to boot off one the partitions. Is that possible ? Thank you. Ldxrunner
Booting from a WD Passport is not supported, nor is it tested.
With regards to partitioning, this can be done in Disk Management:
On the other hand, backing-up your files to multiple partitions at once is up to the application you are using to handle your backups. WD SmartWare and WD Backup are not designed for said purposes at the time of this post. You would need a different application.
Greetings, I like my WD merchandise. I will use the drive as is for backup.How do I use the back up
to help me if something is corrupt on my internal hard drive ?
