It keeps asking me, but I don’t see anywhere to choose?
You don’t need a driver to operate your Clip.
the minimum system requirement for the clip is XP SP2 and WMP 10/11. try installing them first. if you’re not using subscription music, you can just switch it to MSC mode which can be found under settings > USB mode. if you don’t have USB mode, update the clip.
