How do I Convert EDB files to PST file format?
You can convert Exchange EDB files to PST format with this Professional EDB to PST Converter Tool. It can easily convert multiple EDB files to PST format at batch without changing original data. It save converted EDB files into PST, MSG, EML, EMLX, HTML, HTMLX and PDF format. It export EDB files to Live Exchange Server and Office 365 along with all attachments.
Steps to Migrate EDB files to PST format-
  • Open the Exchange EDB to PST Converter tool after successful download to start with the export process.
  • Find EDB File option is available and search the EDB file latest.
  • Click on the file Converting option to go for the export EDB file data into PST file.
  • Instantly the Software starts to export the entire EDB file to PST and displays a message after successful import of the file.
Also, after export of the files, you can split the PST file into smaller sizes for easy access. If you want to know more, you can go for the trial version and explore all the features without any complications.
