I have been running the 'WD SmartWare.swstor" for a while now and the backup location seems to be pretty big now.
How do I configure the SmartWare to back up only the folders/files/extensions I want it to do?
You need to go to the backup tab and switch to file backup. This way you may select the files you want Smartware to backup.
I do a Category backup, see image below, click on, tap or activate image to enlarge it. For what you want to do you will have to do a file backup, see bottom left button for switching to how you want to back up.
See the SmartWare User Manual Chapter 5.
Thanks cat0w
. I see I was running an old version of the program.
