Ok, I got my clip from a friend…and im trying to charge the clip but it wont turn on at all and when it does the screen blacks out and then when i unplug it the clip just shuts off!! Please help me!!
Connect it to your computer for 3 hours and make sure it shows connected on the MP3 player screen and there is a battery icon when you connect it to your computer. ![]()
I’m also having a problem with mine. Lately, when I connect my clip it won’t charge. It says connected connected and shows the batthery icon, but it won’t take a charge at all. It is however showing a computer monitor icon and the clip icon with arrows moving between them, so it almost seems as though it is trying to automatically connect for music transfer.
Message Edited by mel_usmc on 09-04-2009 08:51 AM
Ok thanks ill try it !
