My passport Ultra - How continue back up folders after reinstaling Windows? Folders are on the same partition of hard drive.
passport Ultra - How to continue back up folders after reinstaling Windows? Folders are on the same partition of hard drive.
Hello, faberEm,
Well in order to backup the data on the hard drive in a continues way after windows reinstalling you may use the same software and the same backup schedule or if you face any issue while doing this then you should try contacting WD’s Technical Support about this.
To Contact WD for
Technical Support
