How can I recover Data on Android with Cracked Screen?
Now, you need to focus on a software which can help you recover the broken screen mobile phone data, it is called “Android Broken Data Recovery”.
With this software, you can retrieve the deleted or even lost data from a broken screen phone.
This software applies to a lot of Android phones, for example,  Samsung, HTC, LG, Motorola, Sony and other Android devices.
If your mobile phone screen is broken, your mobile phone into the water can not run, after the mobile phone system upgrade or root your phone screen become black or white, you can use  Android Broken Data Recovery  to restore your data. It will definitely make you satisfied, and it will definitely bring you back the feeling of using the phone.
Detailed method:
How to Unlock Samsung Galaxy S7/S6 with Broken Screen
