You can fix the QuickBooks Error 1612 by resetting the patch file. Follow the steps given below to do it:
- Re-download the patch file if it didn’t work at once.
- Visit Share Download Folder, turn it On and Off, and perform the given series of actions- Off>Save and then On>Save.
- After completing the above step, go back to Step 1 and retry it.
- If the above steps didn’t work, you have to repair the QuickBooks software using Add/Remove or Uninstall\Change in the Control Panel.
- Try Step 1 again.
We hope the steps mentioned above helped you in fixing QuickBooks Error 1612. In case the error persists, feel free to reach us.
