Hi
I have recently bought two My Book Duos for use for backup purposes. I understand that these use hardware encryption. I used the WD Security Software to set passwords. It is a simple and easy process, but there is no reassuring indication that the drives are encrypted. When I’ve encrypted external hard drives using Apple’s Disk Utility it says “encrypted” which I like
In the manual it says that encryption takes place depending on what country you are in. If you are in Russia, for example, there is no encryption. Well I’m not in Russia I’m in the UK and I don’t think there are any laws against encrypting here. However this could be/could not be encrypted element further makes me wonder if the drives are indeed encrypted.
So, is there any way that I can confirm that the drives are encrypted?
Thank you.
