At the beginning and at the end of a record you can hear a very strange noise, so I think it is maybe caused when the record will be saved (by a computing process?)
Does it stop when the backlight or screen goes off? There is a known interference issue. The only workaround is to set your backlight setting to the lowest level, and start your recording that much earlier to compensate (Example: 5 secs.).
