i dont know if this is the right place to do this but i need help i cant download anything to my flash drive PLEASE SUM ONE HELP!!!
One thing you could try is to format the drive (Right Click on the drive in My Computer/My PC and then select Format. Select ‘Restore Device Defaults’ and click ‘Format’) this will remove all data from the USB drive but should solve an issue with the drive’s formatting. www.mybkexperience.com
