I just got a itunes gift certificate but i have a sansa fuze. how do i get itunes movies onto my Sansa 4GB Fuze?
The only way is to use the horribly abysmal program Sansa Media Converter, which doesn’t work very well.
Even then there is no promise it will work often the videos from Itunes are DRM protected
Maybe you want to forget about the movies and use the gift certificate for music instead. Just make sure to get them in .mp3 format (the higher kbps, the better) and DRM-free.
